How can i implement Customized lookup in Report Dialog box.
for example i have two fields in my report dialog 1) Custgroup 2) CustAccount
if i have selected a particuler cust group in first field then second field lookup should show only customers those come under this cust groups.
My code is::::
//class
public class ReportRun extends ObjectRun
DialogField dialogcustGroup,dialogcustaccount ;
CustTable obj_CustTable ;
//dialog method
public Object dialog(Object _dialog)
DialogRunbase dialog = _dialog;
DialogGroup toFromGroup;
Args _args;
str accountnum,custGroup;
// _args = new Args();
// obj_dev_CustTable = _args.record();
//accountnum = obj_dev_CustTable.AccountNum;
dialogcustGroup = dialog.addFieldValue(extendedTypeStr(CustGroup),CustGroup,"");
while select obj_CustTable
where obj_CustTable.AccountNum == dialogcustGroup .value()
CID = obj_dev_CustTable.CID;
dialogcustaccount =dialog.addFieldValue(ExtendedTypeStr(AccountNum),accountnum,"CID");
return dialog;
Any help would be great!!!!
