How to get lookup on TDS group field. Here it’s disable.
Any one please suggest me
I think they are intentionally disabled. Have a look at \Forms\VendEditInvoice\Data Sources\VendInvoiceInfoLineTaxExtension_IN\Methods\active
Why cannot you change them at purchase order line?
Hi kranthi,
public int active()
int ret;
ret = super();
//Enabling the TDS/TCS fields and feature only if parameters are marked.
if (ret && SysCountryRegionCode::isLegalEntityInCountryRegion([#isoIN]))
if (taxWithholdParameters.tdsActivate || taxWithholdParameters.tcsActivate)
element.setTaxWithholdEnabled_IN();
WithholdingTax_Line_TDSGroup.Enable(true);
this.enableExciseFields_IN();
//Enabling the India specific tax fields only for NON PO lines.
vendInvoiceInfoLineTaxExtension_IN_ds.allowEdit(
vendInvoiceInfoLine.isNonPO() ||
VendInvoiceInfoTable.InvoiceType == PurchInvoiceType::VendorAdvance);
//Disabling or hiding following fields for NO PO Lines.
serviceTax_IsRecoverableServiceTax.visible(!vendInvoiceInfoLine.isNonPO());
return ret;
As per client Req they are changed in the invoice line only.
Please send the correct code if any wrong on that
This is code that is responsible for that. You can only edit the data if any of the condition is satisfied.
Try modifying it.
Hi kranthi,
i commenting the above line of code still not getting the lookup
Commenting the below code should enable the TDS group. Do you have any other changes in the form? Also check you don’t have any value in TCS group.
