Can Anybody tell me How to enable Export to Excel (Ctrl+E) in file menu of Report Window (After opening the Report)
Or Please tell me how to export a report in Excel Spread sheet file from AX 2009
I want to see AX 2009 Reports in Ms Office Excel.
Thank you
You cannot export a report data into Excel by doing it.
The alternative way is you can print the report in html file and saving it with the .xls filename extension.
Hi Kranthi,
Thank you for your quick reply
I tried that it is working for me now i am able to get excel file properly from print dialog box.
If i want to open this Excel format of report directly from a menuitem button on form means.
How can i achieve this.
Thanks in advance…[:)]
