im new to Microsoft Dynamic AX…i was working in .Net previously. I have a Form C which contains some textboxes with values. Form A and Form B calls Form C. What i need is when Form A calls Form C, controls shud be enabled and when Form B calls Form C, controls should be disabled. i know we can use args() to do this but i tried my best to use args() and pass it from Form A,B to Form C…But still the result either is its enabled when both the forms call Form C or it is disabled when both the forms call Form C which means default setting is saved…My code to enable/disable even though is triggering but is not having an effect on Form C…
//PurchParmTabletotals is my Form C
The code which i wrote in Form A is:
Args args = new Args();
FormRun formRun;
args.parmEnum(NoYes::Yes);
args.name(formstr(PurchParmTabletotals));
formRun = classFactory.formRunClass(args);
super(args);
formRun.init();
