How to Edit System Fields…
I want to edit Created By, and Modified By Fields in SalesLines Tabll…
Share your Ideas…
Thanks In Advance…[:)]
Share your Ideas…
Do u want to change the field Names a?
If you want to change the Field name . You can change field label in Form field in design.
U can find the Field in datasource add that fields in design and change the lables
Hi Suni,
Want to edit the Data in Fields
Modified by and created by will generating by System.
May I know why should you want to change the Values…
If you want put values u can take new field.
Hi Bobby,
You created a similar post on 2nd March 2011 (http://dynamicsuser.net/forums/p/40319/206787.aspx#206787) to which I replied.
Please do not multi post your queries.
Hi Mohan,
Still i didnt get Sollution for Editing Data in System Fields Like Created By and Modified By Fields
thats y i posted again,
Ok next time…
