hi all am new to ax,
can u pls say how to edit a standard report,
i want to edit the Purchase Order Standard report,
pls anyone help meβ¦
thanx
thanx
Right on the button which is opening the report β go to set up β check the name of the menu item.
Open that menu item and check the object name in the properties
the flow is as PurchFormLetter (class) β PurchFormLetter_PurchOrder(Class) β VendPurchOrderjour .PrintJournal() β
β PurchPurchaseOrder β is the name of the PO report (Confirm)
Hi Arun,
Can you explain your requirments???
Regards
