I am new to AX so I dont know how should I create a line at an angle in AX 2009 as by now we have just come across reports containing either a horizontal or vertical line but I just have a doubt as to how should I generate a line inclined to horizontal or vertical line. Also I want to know as to how should I get the x co-ordinates and y co-ordinates of a point in AX?
As far as I know you cannot have a line at an angle (e.g. 30, 45, 60 degrees). Only horizontal and vertical. If you critically need it you have to draw a bitmap and try to play with i somehow (I did it then I needed vertical text on a report). If its not critical try to avoid this.
I guess, you cannot have X, Y coordinates of the report… at least you cannot get X coordinate.
What you can are:
Get current page’s position in 100mm (1/100 mm) from the top of the page currentYmm100();
Get how much left till the end of the page in 100mm mm100Left();
Go to specific position of the page gotoYmm100();
All these functions can be called from inside of a report (use element if you are in the data source or design method).
