HI all
How to display real values in barcode farmat ax2009.
thanks in advance
nani
HI all
thanks in advance
nani
may be this will help u
display str 30 barcodeRefNum()
Barcode barcode;
str temp;
temp = num2str(tablename.tablefield,2,2,0,0);
barcode = Barcode::construct(BarcodeType::Code128);
barcode.string(true, temp);
return barcode.barcodeStr();
try to use this
hi i wrote like this ,but its not working i mean not scanned though scanning
display BarCodeString barcodeValue()
Str barCodeValue;
barCodeValue = ProdTable.ItemId + ProdTable.itemName() + ProdTable.ProdId +num2str(ProdTable.QtyCalc,1,2,1,0);
// info(barCodeValue);
return barCodeValue;//element.getBarCode().barcodeStr();
try to append values in my code …you will get proper barcode
Barcode barcode;
str temp;
temp = ProdTable.ItemId + ProdTable.itemName() + ProdTable.ProdId +num2str(ProdTable.QtyCalc,1,2,1,0);
