How to display LineAmount
Hello,
I have created new module same as PurchTable Form .
But I can’t display the LineAmount when only put the qty & UnitPrice.
So, Please tell me how to multiply qty & unitprice and display the LineAmount in PurchLine.
You need override the table method “modified field”…
write a case for the field - unitPrice.
in that wirte your code for multilication if qty * unitprice…
here there will be a problem if you have given unitPrice first after that qty the above code will not work…
If you observe the same thing PO - the unitPrice will become zero when ever the qty is modified…
take a look at that…
Hi Akshya.
solution1
  1. open PurchTable Form in designer mode
2.click on LineAmount
  1. right click , view properties
  2. SouceExp = qty * UnitPrice (if you / then u need to check divisior <>0 to avoid infinity loop , here multiple no problem)
5 save & compile.
result : it automatically multiple as u enter
solution 2 :hack [:P]
open any purchase subform save as 50000 & name PurchTable form & remove unwanted column as it already working in standard Navision
samu Thangadurai
Hi Akshay,
Set a breakpoint in modified method under Forms → PurchTable → DS → PurchLine → Fields → PurchQty and follow the code.
You can see it does many things including checking unit conversion, trade agreements etc
@ Samu, do you realise you replied to Ax query? [:)]
Harish My gosh … that was Navision
