Hi there,
Am trying to display multiple default dimensions values into one combined values, separated by –
e.g
Hi there,
e.g
You need to use DimensionAttributeValueSetItem table.
Have a look at \Data Dictionary\Tables\LedgerJournalTrans\Methods\defaultDimensionDisplay_RU
i want to display for PO dimensions
You can use the same code and use PurchLine.DefaultDimension
Example:
while select DisplayValue from dimensionAttrValueSetItem
where dimensionAttrValueSetItem.DimensionAttributeValueSet == PurchLine.DefaultDimension
ret += (ret ? accountDelimiter : ‘’) + dimensionAttrValueSetItem.DisplayValue;
the methods(defaultDimensionDisplay_RU) should it be in DimensionAttributeValueSetItem table or the form
It doesn’t need to be anywhere. I was just giving you a code reference on how to get the display value.
Where you are trying to display the dimension values?
on a from(PurchLineOpenOrder) on a gridview
Write a display method on table and use similar logic (as i shown in my example).
Thanks Buddy
