Hi, if you are talking about that standard dialog, where you set up printing options, standard table ranges etc., then check the “Interactive” parameter for Query in datasources. It should be: Interactive=No
Hi, I had report where i needed to disable dialog, but now i want to add some parameters in dialog (i dont need query, just few parameters), so i changed properties to interactive = yes, but now, report query is empty. What i should do?
