Hi All
In Navision how can i differentiate Letters(a,b…) and Numbers(1,2…)
I want to put a validation in the customer numbers that it should contains only 2 letters & 6 numbers
Hi All
Why dont you create a No.Series and untick Manual No’s
Nope, they will enter nos manually only
Hi, take a look at the string function DELCHR. I have used this as a function in some of my coding solutions:
txtChartoKeep := ‘ABCDEFGHIJKLMNOPQRSTUVWXYZ1234567890abcdefghijklmnopqrstuvwxyz’;
EXIT(DELCHR(BeforeText,’=’,DELCHR(BeforeText,’=’,txtChrtoKeep)));
Parameters: BeforeText - text(50)
Return Value - Text(50)
Variables - txtChrtoKeep - Text(200)
I believe your solution would be a variation to this. Give it a shot!
use delchr to find & remove all letters and then again to remove all numbers - have the remaining characters put into two variables. Use STRLEN to test if you have two letter & 6 numbers and if so you allow the insert else you throw an error.
