I want to decode a JWT token in AL to extract expiration time from it.
How can I do it?
Thanks.
How can I do it?
Thanks.
What is a JWT token?
Erik,
JWT stands for Json Web Token, normally used to authenticate Web API call.
Ok, can’t help you with that answer. [emoticon:c4563cd7d5574777a71c318021cbbcc8]
But you are aware that you now have “native” support for json files in AL?
Seems like it is not possible using AL. Is there a way to call C# or Javascript function in AL?
If you with C# means dotnet, then no. But you can use java script control addins.
Check out [mention:2bb55e765e9542efb188bc24e9c7dba4:e9ed411860ed4f2ba0265705b8793d05]'s blog:
[View:~/nav/b/vjeko:320:50]
He has been writing a lot about using java script with NAV and AL.
