How to deal with EDT with EnumType
Hi everybody,
In Axapta, sometimes you may have to work with EDT which have enum type, such as: LedgerAutoAllocate with enum NoYes, PaymMethod with NetCurrent. And you can not set the value directly with this EDT, but the Enum.
Like: PaymMethod = NetCurrent::CurrentMth;
It takes time to trace back to AOT and check that what enum type of the EDT. Does anybody know a better way to work with these EDTs?
Thank you very much.
Hi Khue and nice to see you and all the others in this new Ax. portal! [:)]
I totally agree on the time spent with these aspects. Some time ago I had created a tool specialized on AOT findings - that’s the Quick AOT addon posted in the Downloads area of the previous version of this portal (mbsonline.org). It doesn’t yet solve this particular issue but you can extend quite easy by adding a new option for the Editor extension. Above that, the tool helps with a lot of other object finding and you might find it helpful.
I will also make the update in a “next release” [:D] and if you have other suggestions I am eager to find about them in order to develop a more consitent and helpful tool.
With regards,
Ciprian Dudau
Hi Ciprian,
I have tried the Quick AOT tool from mbsonline.org . And now I know it came from you.[:)]
I will try to play with that first…
Thank you.
