Hi guys
How to create workflow for PO in 2009.
Hi guys
There is no out-of-box work flow type for purchase order in AX 2009.
It has to be developed.
msdn.microsoft.com/…/cc967389(v=ax.50).aspx
Ok kranthi thanx for giving reply…
i never worked on workflow can u please guide me how to develop a workflow in ax 2009.
You can look at the available templates, Example - ledger journals
Workflow development documentation - msdn.microsoft.com/…/cc967429(v=ax.50).aspx
Please search , you may find some examples (sumitsaxfactor.wordpress.com/…/))
Hi kranthi.
Above Links are i followed, but its not related to my requirement.
please give me any alternate solution for creating PO workflow
What is your requirement that none of standard workflow templates or developer document addresses?
I want create customized PO workflow in 2009. but here there no standred PO workflow ,
how can i create its very urgent kranthi please help me
Doesn’t the developer documentation explains it? Have you tried?
msdn.microsoft.com/…/cc641259(v=ax.50).aspx
yes kranthi i have done all the process
but here when i open purchase order details form workflow status bar was not appear
It would be difficult to say on what went wrong with out knowing what you have done.
What changes you have made to that form?
Ok kranthi thanx
here in the below link Zip file is there i downloaded that file and followed the same steps but yellow bar was not appearing. please check it once
www.axaptapedia.com/File:Workflows_-_Development.zip
Did you configured the workflow properly?
Yes i configured properly… do i need to put full CIL after the process which i have followed based up on the doc
There is no CIL in AX 2009.
Ok do i need to restart the services…how can get that yellow workflow status bar is there any other way to get
Not necessary. Do you have canSubmitToWorkflow method on the form? If so what does it returns in your case?
public boolean canSubmitToWorkflow()
return purchTable.canSubmit();
its return true
Can you also check if WorkFlowEnabled and WorkFlowDatasource properties are set on the form design?
You may visit the following sites listed below.
AX 2009 Workflows: A Quick overview
Create New Workflow in Dynamics Ax 2009 - Steps
Talking about Developing a new Workflow
Setup and Configuration of the Workflow for Microsoft Dynamics AX 2009 Administration
