How to create pages in NAV 6.0 SP1
Ever consulted the C/SIDE Reference Guide aka MS Dynamcics NAV 2009 SP1 Developer and IT Pro Help?
Have a look at this topic: Page Designer Walkthroughs.
Thanx Luc
There are two ways to create pages in Navision 6.0
- If you have existing forms and you want to create Pages from that you can use an easy way by using **transformation tool (**u can find this on Product CD).
1. what you need to do is export existing forms from the Navision and export them as Forms.xml.
2. Copy that xml file into Transformation tool and run the EXE, it will generate Pages.xml.
3. Import that into NAVision and compile new pages.
4. Done.
- You can download NAV 2009 C/SIDE Introduction Material From Partner source and read the pdf for Pages.
I would personally suggest you to go using method 2, because u will learn how to create pages well.
