i want to create number sequence with this format
yy.mm.dd.xxxx
yy=years = 15
mm=month = 04
dd=date = 05
xxxx = continous number sequence
example:
15.04.05.0001
15.04.05.0002 and etc…
when date >= 25 number sequence reset into 1
15.04.25.0001
15.04.26.0002 and etc …
how to solve it?please help me.
you need to populate value of yy.mm.dd by progrmatically.
use no. sequence for xxxx…
finally concatanate both the values…
Str numseq = numberseq::newGetNum(NumberSeqReference::findReference(TypeId2ExtendedTypeId(TypeId(EDT))),true).num();
above line generate the Number Seq and convert your req date into string
then Concatenate the both string
static void TestCases(Args _args)
info(date2str(today(),321,2,2,2,2,2)+ ‘.’+“00001”);
// you can replace 00001 into your numberseq and try
