I want to create lookup in grid field which will have multiselect option (multiple row selection).
I tried Syslookupctrl but is doesn’t work wth grid.
Is there any way to create same?
Rahul
Rahul
Hi Rahul,
just refer this link, It might Help u
http://kashperuk.blogspot.in/2008/09/sysmultitableloookup-dynamic-lookups.html
Hi Rahul,
Follow this link, this will solve your problem of creating multiselection lookup.
http://yasirnedian.blogspot.com/2012/07/how-to-select-multiple-selected-values.html
Yasir
Hello,
I know this is already nearly 3 years old, but I’m having the exact same problem right now.
I want to create a lookup on a GRID field control with multi selection.
I also tried the above mentioned links, but nothing is working. With SysLookupMultiSelectCtrl class, I’m getting an AX crash when using for a GRID field control. Outside of grid, it is working fine.
Someone has an idea?
Kind regards
AnonX
Hi Anon X,
For grid you must use SysLookupMultiSelectGrid class, not SysLookupMultiSelectCtrl.
