I want to show a form in another form look up.
ex : I have a customized form,where i have a field invent serial number.In serial number lookup i want to show invent trans form.
what i need to do?
what i need to do?
Hi Shashank,
In the customized form,datasource level – field invent serial number – overiride the method lookp() and write the logic over there…
public void lookup()
SysTableLookup sysTableLookup = SysTableLookup::newParameters(tablenum(TableName), this);
Query query = new Query();
QueryBuildDataSource queryBuildDataSource;
QueryBuildRange queryBuildRange;
sysTableLookup.addLookupfield(fieldnum(TableName, fieldname));
//BP deviation documented
queryBuildDataSource = query.addDataSource(tablenum(TableName));
queryBuildRange = queryBuildDataSource.addRange(fieldnum(TableName, fieldname));
queryBuildRange.value(Global::queryNotValue(TableName.fieldname));
sysTableLookup.parmQuery(query);
sysTableLookup.performFormLookup();
Naresh Kolli
Thanks Naresh,
But what u have written is normal look up for serial number.In my customized form, in serial number field i need a look which contain all the field as in invent trans.
Invent trans form contain both invent trans and invent dim data source.In my form serial number field i want to show the invent trans as look up,Means the look up should contain invent dim as well as invent trans.So when i click drop down of my serial number it should show the invent trans form and serial number as range.
So you have created a look up form.
Actually the Invent Serial Id look up comes from the - Form specified in the Form Help property of the InventSerialID EDT.
Try by changing that - you can also look into the InventSerialIdLookup form - for how to create a look up form…
