How to create hyperlink in excel document with ax ++?
Hello;
I need to create a hyperlink in a cell inside the xxcel document. How can I do this with x ++?
Thanks.
I used the hyperlink formula in the Excel document. I dynamically create a formula from within Axapta and write it as value to the corresponding cell.
Hello Recep,
it would be great if you share example , will be helpful for many others having the same problem :slight_smile:
worksheet.name(strfmt("%1 Page",pageNumber));
//in mainWorkSheet
cells.item(row,5).value("=HYPERLINK("#"&"’" & “+strfmt(”%1",pageNumber)+" &" Page"& “’!A1”;“Graphic”)")
thank you Recep,
it will be very helpful to other people with same issue
