HI All,
I need to create a multiselect dimension lookup(Value and name).
i have tried the following but didn’t get the solution
- Using DimensionvalueLookupHelper class i got both the name and value, but multiselect option was not there
DimensionValueLookupHelper::lookupDimensionValues(dimensionAttribute,_ctrl)
- Using SysLookupMultiSelectCtrl and DimensionAttributeValue table i got the multiselect option but didnt have an option to include a method(getname()/getValue())
Query query = new Query();
int mutiSelectTableNum = tablenum(DimensionAttributeValue);
container selectedFields;
query = projectSSRSHelper::Dimension1Lookup(dimensionAttribute);
selectedFields = [mutiSelectTableNum, fieldname2id(mutiSelectTableNum, fieldstr(DimensionAttributeValue, DisplayValue))];
SysLookupMultiSelectCtrl::constructWithQuery(this.dialog().dialogForm().formRun(), dimension1.control(), query, false, selectedFields);
class ProjectSSRSHelper
public static Query Dimension1Lookup(dimensionAttribute _dimensionAttribute)
QueryBuildDataSource qbds, qbds_join;
QueryBuildFieldList qbfl;
qbds = query.addDataSource(tableNum(DimensionAttributeValue));
qbds.addRange(fieldNum(DimensionAttributeValue, DimensionAttribute)).value(SysQuery::value(_dimensionAttribute.recid));
qbfl = qbds.fields();
qbfl.dynamic(false);
qbfl.clearFieldList();
qbfl.addField(FieldNum(DimensionAttributeValue,Displayvalue));
qbfl.addField(FieldNum(DimensionAttributeValue,DimensionAttribute));// as we dont a have description/name field.
return query;
is there way to add getname() method of DimensionAttributevalue table as a field list.
can anyone help on this
