I am working on AX 2012 R2.
I have a requirement to create particular number sequence code or voucher series as shown in below for list of companies.
While creating t through X++ code I am facing the difficulties to select company and segment as shown in below.
Please suggest any if you any thoughts on this.
Hari
Hi Hari,
I am not sure with this .This may helpful to you…www.dynamics101.com/…/
Are you trying to create number and voucher sequences through code? If so look at the code behind number sequence wizard which almost does the same. (Number sequences, then click generate)
Hi Gopinath,
Thanks for your reply,
The above link is to generate number sequence for particular module and particular EDT.
In my case I have create number and voucher series for existing EDT. As I show in the above screen shots.
Hari.
