I want to create a batch number and assign to the particular item.
How to create batch number for the particular item programmatically?
Thanks in advance,
Hari
Thanks in advance,
Hari
static void createBatch(Args _args)
InventBatch inventBatch;
InventTable inventTable;
NumberSeq numberSeq;
inventTable = InventTable::find(‘YourItem’);
ttsBegin;
inventBatch.initValue();
// you can assign your own number or use the sequence
numberSeq = NumberSeq::newGetNum(InventParameters::numRefInventBatchSerialId());
inventBatch.InventBatchId = numberSeq.num();
inventBatch.ItemId = inventTable.ItemId;
inventBatch.prodDate = systemDateGet();
inventBatch.insert();
numberSeq.used();
ttscommit;
Consider updating the shelf life, best before date, if they are enabled see \Data Dictionary\Tables\InventBatch\Methods\pdsSetShelfLifeBestBeforeFields
