I am a beginner. I need help. How to create a report for picking data from different tables from the sql server database
please reply to me the detail steps of this.
Thanks in Advance,
sami
Thanks in Advance,
sami
Hi Sami
Designing report is will not differ based on the database type(SQL or Native) you are using.
Your task is you have to get data from two different tables.follow the below steps.
Lets take sales header and sales line table for example
1.Set Sales header as your first data item of your report.
2.Set sales Line as your second data item.
3.Make one step right ineddation of sales line data item
4.go to the properties of your second data item(Sales Line) end give dataItemlink between Sales header and Sales Line.for example
Document Type=FIELD(Document Type),Document No.=FIELD(No.),Sell-to Customer No.=FIELD(Sell-to Customer No.)
the meaning of above line is
Document Type of line tale = Document Type header
Document No. of line table = Document No. header
Sell-to Customer No. line table = Sell-to Customer No. of header;
5.now you can design your report
6.Save,Compile and Run
Jerome MArshal.J
Hi Marshal,
Thanks for your reply which is helpful to me.
I don’t have the Software to practice. Could u tell me how to get the software on the internet for practicing this
thanks,[:)]
sami
You can download this software from www.mibuso.com or other microsoft websites.
Once you have the software you should look at the Application Designer’s Guide that comes with it. You’ll find a chapter on report design there.
This thread has been split off to
Create a Navision report with something similar to an Inner join in SQL
Please make in sure future to start a new thread for a new topic.
Hi Marshal,
I follow your task and succes…
I have another problem…and let me tells the detail
My Question is : why that textbox do not shown the data?
Thx
Hi Hendra,
It is not enough to declare the record for table B, you have get the record with a FIND statement
Hi Dave,
Example : show data of Table Company Information in report Sales Order…I see that report just only set in properties Source Exp.
Can u help how use that?
Tq
it might have CompanyInfo.GET; in onprereport trigger…
