In node Table of AOT, i create new table and i want to set a primary key to a field ,which means that values of the field should be unique among the table values and want to make it auto-increment.
How can i do that.
Thank you.
How can i do that.
Thank you.
Create a primary index, by using that field and make the field mandatory.
You need to handle it through code, by using a number sequence.
Keep the SurrogateKey as primary, unless you have a good reason to change it.
Create an index. Add a field / fields. Set the AllowDuplicate property to No to create an unique index.
SQL-style auto-increment is not used in Dynamics AX. If you just want a surrogate key, you already got one when you created a new table, so you don’t have to do anything. If you want an auto-incremented user-facing value, use a a number sequence.
Please consult the documentation to learn more information: Indexes and Keys [AX 2012]. Note that you can use a search engine to find the documentation you need.
suppose u are having table student table , having field RollNumber ,rollnum u want as unique and incremental
@studentTable
| --------- studentName
|---------- RollNum
|---------- address
in the table ther is a node named as index ,Right click on it and say new index. Suppose I created new index with name Index1.
den on that newly created index drag the field roll num in it .
it will looks as :-
Index1
|------RollNum
den set the property of Index1 as AllowDuplicate to “No” and alternate key to “Yes”.
the go into ur table property where u can see Primary kEY , bydefault its value is surrogate key ,in the drop down u can see ur index nem whch we nemed as Index1 select it.
and save ur table .
for incremental u should use num sequence
Thank you all
Could you please mark the reply/replies that answered your question? It will also show the whole thread as answered.
