Dynamics NAV 5.0 W1 Service Pack 1 Client
Client software: CsideClient50SP1.rar
I want to connect with my SQL server to store the databases there, and look at them throuogh the navision client.
(I want to store the demo database on my SQL 2008 server)
My option for SQL server is dimmed. Do I need to install something more?
With the installation i choose for the “minimum” version, which was already selected (I pressed next al the time).
You apparently have run the fin.exe (aka Microsoft Dynamics NAV), while you should be running finsql.exe (aka Microsoft Dynamics NAV with Microsoft SQL Server).
You said you used the RAR file? Did you download the demo from this website?
Then I think that you will need a “real” production license to use it with the SQL Server 2008. You can only use the demo license with the included SQL Server.
In regards to the above installation error, then you should try start is with the “Run as administrator” option.
…MSDN has it - in VS Premium and VS Ultimate subcriptions.
…the installation procedures. only Admin or user with Admin rights can update Windows system components, message in your last screenshot says your’e trying to update protected system files.
Besides - Erik was in doubt will you be able to use your existing SQLServer with DEMO license. You will, I myself used DEMO license even with SQL 180-day trial for demonstartion purposes for prospects.
@Modris Ivans: are you saying it is possible to use Navision demo with SQL 2008 server?
If I open the SQL2005 management studio, and try to connect with my standard server (ELLENWINDOWS), it gives the message that I can not connect with a SQL 2008 server with SQL2005 management studio…
and managed tow create the 2 extended stored procedures.
Now I am left with 2 questions:
How to get the example data base of Navision into my SQL2008 server, so I can perform SQL statements on the example database in my SQL2008 management studio?
I have 2 options with navision:
In the CSIDE client there is a example database, in the other one not…
Also in the first Navision I installed I had 2 example databases/companies (CRONUS internatioanal, and also a CR?? Nederlands)
Now I only have the international one. No idea how I get the “nederlands” example database anymore…
The 2nd less important question:
How do I get rid of the error 1931. I am the only user of my Windows, so I am the admin. What should I do?
I had an expert of forensics come by, and he made it work. It seems a problem with my users in SQL server, he changed a user (after 45 minutes of trying all kinds of stuff).
When I told him about the tag and the xp-ndo he said it was comon with Windos XP.
So maybe it is something for Navision to put that someplace?
