Janoa
January 20, 2013, 3:39pm
1
Hello,
I made a windows Server and a Client. I connected the Client to the server and this works, because I can successfully ping to the Server. Now my problem is that everytime that I run MS Navision 2009 on the client it says it’s not connected, and when I press ‘No’ I have to insert the server address.
When I insert “localhost:7046/DynamicsNAV” it says
‘A server was not found at “net.tcp://localhost:7046/DynamicsNAV/Service”. Either the URL is incorrect or the server is currently not available.’
Now what could cause this error and how can I fix it?
Thanks in advance!
~Jano
What is the name of the windows server ?
Janoa
January 20, 2013, 9:55pm
3
Thanks for your reply!
I’m not sure, is that the computer name?
Or the one I gave during the setup at the Installation Parameters?
Thanks!
craazzz
January 20, 2013, 10:24pm
4
go to control panel and then look for system and open it.
under system look for computer name tab and click on
it. click on the change button on this window where you
find the computer name written
check it and give me a snapshot so we continue from there
Janoa
January 21, 2013, 11:35am
5
Here you go!:
Is this also the server name? Thanks!
You should replace localhost with Windows server Name
WIN-N0H-3P5TN8UT:7046/DynamicsNAV
Janoa
January 21, 2013, 11:45am
7
Thanks for your reply, Mohana!
It still doesn’t work, I get the same error:
What am I doing wrong?
Also, if I ping that computer name I get 0% loss
Is NAV Server running in Windows Server?
For your Information, I just typed your server name
Please check the name again whether it should be zero or letter O
Janoa
January 21, 2013, 11:50am
10
How can I check that?
The services are running:
(Btw it’s a zero )
try with your domain also
WIN-N0H-3P5TN8UT.:7046/DynamicsNAV
ex:
WIN-N0H-3P5TN8UT.google.com:7046/DynamicsNAV
if your domain is google.com
You can check database name and port in config file which will be under
C:\Program Files (x86)\Microsoft Dynamics NAV\60\Service
Open custom Settings file and check DatabaseServer, DatabaseName, ServerInstance and ServerPort
Janoa
January 21, 2013, 11:57am
13
That still doesn’t work! Same error.
My domain is without an extension (so without .com/.local), it’s just a word like ‘dinosaurs’. Is this a problem?
Janoa
January 21, 2013, 12:00pm
14
This is what is in the custom file:
Sorry forgot the last part;
ServerPort = 7046
WebServicePort = 7047
Please check whether you can connect from Windows machine or not?
Janoa
January 21, 2013, 12:06pm
16
I’m sorry I don’t understand. Do you mean if I’m connected from the client to the server? I can successfully ping to the server with 0% loss.
You are connecting from Client to Server.
I am asking you to connect from Server to Server only…
Janoa
January 21, 2013, 12:23pm
18
What do you mean? I can run ‘Microsoft Dynamics NAV 2009 Classic’ on my server, but I haven’t installed the client version on my server. Should I do that and try if it works there, is that what you mean?
yes, Install RTC in server and try to connect
also classic on client machine and try to connect
Janoa
January 22, 2013, 9:59am
20
I installed the RTC on my server and it automatically connects there.
I installed the Classic Client on my client, but I get the following error:
