How to completely hide or deactivate discontinued products?
Hello everyone,
We are using Dynamics 365 F&O and I need some guidance regarding product deactivation.
We have about 100 items that have been discontinued, and we want to completely prevent them from appearing when a user creates a Purchase Requisition.
I tried using the “Stopped” flag under Default Order Settings, but the product still shows up in the lookup/search. When the user selects it, the system just throws the “Product is stopped” error message.
In our scenario, we only use the ERP for purchase requisitions; we do not have any inventory movements for these items.
Is there a standard, out-of-the-box way to fully deactivate or hide these products so they don’t even appear as an option for the end-user?
Thanks in advance for your help!
Hi @Maria_Alice_Santana
The “Stopped” flag blocks orders at validation, not at lookup, so products still show up. That’s expected F&O behavior.
Quick Fix (No Code): Add a custom lookup filter on the Purchase Requisition form to exclude items where Status = “Stopped”. Takes an hour.
Better (Low-Code): Create a “Discontinued” product attribute and filter lookups against that instead.
Full Control (X++): Override the lookup datasource with a where() condition to completely hide discontinued items.
For 100 items, the custom lookup filter is your fastest win.
I remember you had a similar product visibility issue back in October. This might be worth a deeper look. We can help you build a scalable solution, or just guide you through the lookup approach, let us know what works better for you.
How can we help?
You can limit Purchase requisition users from seeing certain categories by setting up Category access policy rule: Procurement and sourcing/Setup/Policies/Purchasing policies
You can also Hide all products per category in your Procurement catalog: Procurement and sourcing/Catalogs/Procurement catalogs
Or you can remove single items from you Procurement category under Products fasttab: Procurement and sourcing/Procurement categories
You achieve the same outcome as the previous if you remove an item directly from Category hierarchy that is the basis for your Procurement category: Product information management/Setup/Categories and attributes/Category hierarchies
And you should of course use Product lifecycle state to block discontinued Released products.
