Can anyone please explain on how to clear the records in table box before submitting a search criteria?
The problem here is - in my custom form, the table box displays the records as per the search criteria PLUS the last record from the previous search. So I need to clear the table box while submitting the search criteria (just before displaying the new resultset).
You need to expalin what you are doing here. At a guess it looks like you have created some custom search tool, but how can we know that or know what code you have written, or even help you if you want to keep all that a secret. [:(]
I have a custom form with a text boxes and a table box. The text box accepts search value (date - defaulted to Current date) for the “Alert Date” field (custom field added on Comment Line table) and displays corresponding records on Table Box.
I’m using a single line of code on the OnValidate() trigger for the Alert Date textbox and it is as follows.
CommentsAlertDate is a variable that takes TODAY; as the default value when the Form loads.
When I open it for the first time, the form displays all the comments for current date. But, when I try to search comments for another “Alert Date”, the table box is not clearing all the records. The last record from the previous search remains there.
Well, I’m afraid the first line doesn’t seem to be good. I refered to use the RESET function of your record var (the one you use to make the SETFILTER), ej:
We are trying to make a screen where our Credit Control department users can search for entries added on Comment Line table.
The Credit Control department uses the customer comments sheet for adding the follow up details or other comments whenever they make calls to the customer.
Now, they require an option to add the next follow up date (Alert Date) and a search functionality on comments table based on the Alert Date field.
We’ve added one more field to store the user name to the comment line table. Our aim is to provide the user with an option of seaching the comments - filter by user name / alert date.
Right now our code is as follows. This runs in the OnValidate() trigger on a text box control.
In the comments list form there is a event which fires on “double click”, would be interested to know how can I do the same. Tried to look around in that page for the double click event but didn’t find it. Can you guide us as to how to do that.
It doesn’t really exist this “double click” event, it’s an internal function when you display a LookUp form. For example if you go to Orders and press F5 you’ll be able to “double click” on the list and the current order will be displayed on the form Card.
If you put code on the “OK” button of the form, this will be executed when you “double click”, maybe you can try something this way [*-)]
