How to change the background color
How to change the background color in axapta techncial
where you want to change in form or report.
please be clear then only you can get the better solution.
form and table level
Hi Vardhan,
in the form > grid > controls… select the properties
set the ColorSchema as RGB, and select the BackgroundColor as u want.
thanks,
Valeru.
hi…
change the color of Microsoft Dynamics AX 2009
In the class SysSetUpFormRun class add a following code in run method
public void run()
super();
this.design().colorScheme(FormColorScheme::RGB);
this.design().backgroundColor(WinAPI::RGB2int(255,0,0));
Regards
It solved my problem. thanks for sharing:)
