Hi, I want to change the forecolor in a order-form but not for the whole column. Only some special items should get a different color. So I need a solution to ‘link’ the forecolor with a restriction. HELP?!
You can do this in the OnFormat trigger of the field you want to change. E.g. you want toe change the colour of column “description” to blue (16711680): IF something THEN CurrForm.Description.UPDATEFORECOLOR(16711680);
Hi Steffens As a side point if you have any questions regarding the object designer aspects such as this question. You should really direct those type of questions to the: Attain/Financials - Developer Forum which answers questions and discussion about development and modifications in Navision Attain and Navision Financials. _________________________ Wendy O’Connor Practice Leader woconnor@csbsystems.com CSB Systems Calgary, Alberta T2R 1L9 T:(403) 233-2955 x 224 F:(403) 233-2957
