Hai,
Is there any possibility to change the Report caption Name at Runtime in navision 3.7.
Anilkumar.N
Hai,
Anilkumar.N
Hi Anil,
What do you mean by Report Caption Name?
If you ask if you can change the caption of a field on a report on runtime, then the answer is yes. But you need to replace the actual label by a text box (with the same properties as a label so they look the same) with a variable as the source. Then you can just asign any value to the variable.
