How can I cancel or Undo a Confirm on the Purchase orders?
I created a sales order with dynamics AX 2012, and, i confirmed that data.
but, I found some mistakes, and i have to cancel a confirm.
Note : The Method is to cancel a confirm on the Purchase Order
You say purchase order, sales order, purchase order [:D]
You cannot cancel a confirm, if you have not sent it to the vendor simply delete the line, enter a new line, re-confirm, or just re-confirm you get the history of all of the confirmations then. It is a control mechanism to prevent incorrect orders being processed, but if they are they are somply altered and re-confirmed.
That would cancel the order, the request is to cancel the confirmation. You can reset the status to approved bby editing the line, but you cannot “cancel” a confirmation once a confirmation has been made, and in reality there is no need.
The confirmation is a stage in teh PO and it is where you issue the PO - there is no need to cancel this stage. If you want to cancel teh purchase order then the suggestion is correct, or you could just have pressed delete, but both have to be backed up with communication to the supplier.
