i m trying to sum amount month wise and display it like
Month |
Currency code |
TurnOver |
Jan |
Usd |
12211 |
Eur |
21211 |
Feb |
Usd |
2121345 |
Eur |
213114 |
Mar |
Usd |
4541 |
Eur |
11313 |
Apr |
Usd |
1545 |
Eur |
456 |
May |
Usd |
54 |
Total |
Usd |
131145454 |
Eur |
1444645654 |
Create a group to the Month,Currency code key.
I am new to Nav ,but i tried to create this report using array is this a right way?
Are you using NAV 2009 or 2013?
Hi Divyesh,
You need to provide more information on report such as
Which dataitems you are using for creating reports
You are using array and somebody will use key to generate the reports .You need to think in different possible ways to make your report performance faster and finally the output matters to end user.
Hi Amol Sir ,
Sir i have prepared Statics report by taking array of dimension 12 and then storing the amount month wise
and currency code wise
SalesInvoiceHeader_gRec.RESET;
IF SalesInvoiceHeader_gRec.FINDFIRST THEN BEGIN
REPEAT
SalesInvoiceHeader_gRec.SETFILTER(“Posting Date”,’%1…%2’,sdate,edate);
Pdate:=DATE2DMY(SalesInvoiceHeader_gRec.“Posting Date”,2);
IF i=Pdate THEN BEGIN
IF SalesInvoiceHeader_gRec.“Currency Code”=‘USD’ THEN BEGIN
SalesInvoiceHeader_gRec.CALCFIELDS(“Amount to Customer”);
SumInvoice[i] := SumInvoice[i]+SalesInvoiceHeader_gRec.“Amount to Customer”;
END;
IF SalesInvoiceHeader_gRec.“Currency Code”=‘EURO’ THEN BEGIN
EuroSum[i] := EuroSum[i]+SalesInvoiceHeader_gRec.“Amount to Customer”;
END;
END;
.this code is only for two Currency code but i want to print all currency code with there amount dynamicaly.
You have hardcoded the currency code for two .
You need to take currency as dataitem in report and do the programming accordingly…
How can i get this report dynamically sir?
