How to bypass empty records based on a field
hdsDailyReceiptsTmp.ReceiptDate = queryEWMLP.TransDate;
hdsDailyReceiptsTmp.WMSPalletId = queryWMSPallet.wMSPalletId;
hdsDailyReceiptsTmp.ReceiptsListId = queryEWMLP.HDSReceiptListId;
hdsDailyReceiptsTmp.PurchId = queryEWMLP.PurchId;
hdsDailyReceiptsTmp.insert();
I am inserting records into a table like above. If the above two fields are empty**(Highlighted in Bold)**. I want to bypass those records before inserting into the table.
RK.
Hi
Please add Condition before inserting
the following code just example so add condition as per you requirements
if (queryEWMLP.value() != “”)
I hope that it’ll work
Regards
Don’t forget to verified solution if solve issue
if(queryEWMLP.HDSReceiptListId || queryEWMLP.PurchId)
if(queryEWMLP.HDSReceiptListId && queryEWMLP.PurchId)
