Tarak
October 21, 2009, 2:44pm
1
I am trying to recreate our NAV environment from our production server to a development (dev) server for testing purposes. Does anybody have specific directions or instructions on how to do this?
Specifications:
Server 2003 R2
Sql Server 2005
NAV 5.0 SP1
DRB
October 21, 2009, 2:50pm
2
Hi Tarak,
Do you want to know the procedure for taking back-up and restore, if yes then
For taking backup: From Navision, Tools>> Backup >>Entire Database and select two booleans at the bottom , give the path and the system will backup.
For restore>> Tools>> Restore and give the path to earlier back-up file.
The other option is using “.bak” file, by first taking backup from SQL server and then restore that on the new server. I prefer doing by first option.
In case you have any other specific question, then do post it here.
Tarak
October 21, 2009, 3:06pm
3
Thanks for that quick response.
Tarak,
Were you able to solve your issue of recreating your database in a different server for testing? I have the same issue now.
I have tried backing up the database (fbk) to try and restore it on our test server but I am getting an error. (see attached)
I have also tried restoring a “bak” file on the test server and connect to it using msnav client but I’m getting the same error as above.
Any assistance will be appreciated.
