Hii, I want to assign a hotkey and when it is pressed a specific form will run … this key will be valid across Navision… is it possible creating a functionality like Navision Help? Thanks…
I’m afraid this is not possible but… If you put a function with the hotkey (e.g. F9) on the main menu, the users can always enter that function by typing F12 F9.
HI Its not that easy tp create hot keys directly is quite possibe using OCX Controls and make sure you are not using any of the standard HOTKEYS already availabe.
