Hi
I want to sort by also for my date column, how to add with this code
public void executeQuery()
qbr = SysQuery::findOrCreateRange(jsProShipShipmentStatus_q.dataSourceTable(tablenum(jsProShipShipmentStatus)),fieldnum(jsProShipShipmentStatus,ShipDate));
qbr.value(Sysquery::range(fromdate.dateValue(),todate.dateValue()));
super();
Isn’t your code in jsProShipShipmentStatus data source? It should be, and it it is, you can replace this:
with this:
this.queryBuildDataSource()
Regarding sorting, consider simply setting Index property of the data source.
If you need it in code, use addSortField() method of QueryBuildDataSource. I assume you want to always sort by this field, therefore you should do it in init() (not in executeQuery()):
public void init()
super();
this.queryBuildDataSource().addSortField(fieldNum(jsProShipShipmentStatus, ShipDate), SortOrder::Ascending);
i want to sort when we change from and to date once the grid is loaded i want to sort ascending
Unfortunately I’m not sure what you mean by this statement. Are you confirming that the solution works for you or are you indicating that you have a business requirement that isn’t covered by this solution? If it’s the latter, you’ll need to tell us what what the requirement is.
