how to add some column in the batch order form e.g Item discription of finished gooods for which the order is made.
Item Name will be there in General Tab of batch orders.
You need to take help of a developer to do add more fields to that (or) try to learn some basics in x++ development.
are you sure I need to modify the code?
item discription is comming in other logins …which I’am not able to see.
I am talking aboute adding “item discription” column in the overview tab of the bach order.
Development not only means writing some code…
Check whether the field has been hidden or not.(right click - hide)
right click on the form - information - form name - edit - the form will be opened
Open the design node - move the Item Name from General Tab to Overview tab.
