How to add more currencies ((which are not supported)) to default currency provider in AX 2012
I need your urgent help, while trying to import currency exchange rates i faced this msg “An exchange rate could not be found for ISO currency codes AUD and AED, on the following date: XX. Verify the ISO currency codes that are supported by the provider and that are available for the requested date.”
I realized then these currencies are not supported by the default currency provider in AX , My question is how to add more currencies to Provider list?? I don’t want to add them manually, and also i don’t want to go for option to create a NEW currency exchange rates provider, as you know it is complicated approach.
Your prompt reply will be highly appreciated.
Best regards,
Hi Razan,
You have also posted the same question on the Dynamics Community. Again:
The exchange rate provider reads exchange rate information from e.g. a central bank. This bank is providing information. If they do not support the currency pair, you cannot add it yourself in the provider. The provider is only reading external information. There are some providers like Bloomberg which provides almost all currency pairs. This is not a free service. E.g. the European central bank is free to use.
So or you have to fill exchange rate information about the missing pairs manually or you have to find another provider which has more currencies and is also allowed to use in your country/region.
Hi Andre,
Thank you very much for your assistance, actually i post them on the same time hope to get the proper answer from an community :slight_smile:
