but while posting packing slip or Invoice i got the below runtime error as shown below:
As the ledgervoucher class is a abstract class, it is causing some problem. Could you please tell me what exactky is the problem and how to resolve it.
This is typically caused by not compiling all relevant objects - try to use Compile forward on the LedgerVoucher class. If you have such problems in your application, it may be worth to compile the whole AOT.
If it doesn’t help, analyze which line of code throws the error.
