How to add field in InventValueReport
Hi everyone,
I make one field with name : Description. I want to get information from table EcoResProductTranslation with field Description and insert this information in InventValueReport(InventValueReportTmpLine).
After I add field , which i make - Description , in InventValueReportTmpLine. I go to DP and insert field in macro.
After this I mean , i must go to InventValueReportPopulateItem , but I don’t know how to implement code ther first to join tables and after this to insert information in field.
I will join table like this with little changes.
\Classes\InventValueReportPopulateResource\findReportLine-> this is where the itemId value is assigned. Try having your code here.
tmpReportLine.Description = _inventTable.defaultProductDescription();
But when I debugged it - the value is empty . Can you help me ?
And after deploy in VS Project , also empty
Look at the _inventTable record values. Are you getting a value for inventTable.product field.
If not, use find method. InventTable::find(_inventTable.ItemId).defaultProductDescription();
When I debugged it looks good
but when I deploy VS project and run Report From Ax view
Inventory management/Reports/Inventory value /Inventory value - Field is empty
Try by restarting the SSRS service. It could be a cache issue.
