I need to add the ARPTaskId_Wbs field (from an ISV) to a copied version of the ExpenseJournalLineEntity data entity.
The field is not stored in the database but is calculated in the form using the following method in the ISV extension:
[ExtensionOf(tableStr(LedgerJournalTrans_Project))]
public final class LedgerJournalTrans_Project_ARP_Extension
/// display/edit
public static edit ARPTaskId_Wbs ARPTaskWBSId(LedgerJournalTrans_Project _this, boolean _set, ARPTaskId_Wbs _wbs)
[_wbs, _this.ActivityNumber] = ARPTasktools::TaskWBSId_edit(_this.projId, '', _set, _wbs, _this.ActivityNumber);
return _wbs;
Since LedgerJournalTrans_Project is already part of my entity, I am trying to create a computed field to retrieve ARPTaskId_Wbs dynamically.
Here’s what I have so far:
public static str computeSID(ProjActivityNumber activityNumber)
LedgerJournalTrans_Project ledgerJournalTransProject;
// Retrieve the record based on ActivityNumber
select firstonly ledgerJournalTransProject
where ledgerJournalTransProject.ActivityNumber == activityNumber;
// Ensure a record is found before calling the method
if (ledgerJournalTransProject)
return LedgerJournalTrans_Project_ARP_Extension::ARPTaskWBSId(
ledgerJournalTransProject,
false, // Boolean flag
'' // Placeholder for ARPTaskId_Wbs
return ""; // Return empty string if no match is found
So the issues I’m seeing:
- The computed field is not retrieving any data, and I am unsure if I am calling the method correctly.
- The
ARPTaskWBSIdmethod is defined in an extension but does not seem to work inside the computed column. - Should I be calling this differently, or is there an issue with using a computed column in this case?
Has anyone successfully retrieved an ISV-calculated field in a computed column inside a copied data entity?
Would it be better to store this value instead of computing it dynamically?
Any help would be appreciated!
