How to add beginning inventory for company with Advanced Warehouse Management (Directed pick-putaway + Zone + Bin) and Lot / SN
Hello
I have imported only items without price and stock and the database is new and blank
how to do calcualte inventory with all items that are with stock 0 in warehouse physical inventory journal ?
To calculate the expected inventory in advanced warehouse configurations:
Synchronize item ledger and warehouse before you count physical inventory. Otherwise, what you post to the physical inventory journal and item ledger is the physical inventory results combined with other warehouse adjustments for the items.
  1. Choose the Lightbulb that opens the Tell Me feature. icon, enter Warehouse Physical Inventory Journal, and choose the related link.
  2. Choose the Calculate Inventory action to open the Whse. Calculate Inventory page.
  3. Set the filters to specify the items to count in the journal, and then choose OK.
Business Central creates a line for each bin that meets the filter requirements. You can delete lines, but if you want to post the results as a physical inventory, count the item in all the bins that contain it.
If you only count an item in some bins but not others, you can enter differences and post them in the Item Journal page later by using the Calculate Warehouse Adjustment action.
You can find more information here:
Count, adjust, and reclassify inventory using journals
Javier Diazgranados
Supply Chain Analyst
Sabre Limited
