Looking for some help with this issue. I have a new AX company defined. Previously defined SSRS reports do not allow me to select this new company in the report parameters. How do I add a new company to the SSRS reports parameters so it is available for selection/use?
Try creating new report parameter say CompanyID, then manually add newly added company ID as one of the value of the parameter. This should let you select new company as a parameter to the SRS reports.
in the report manager… when u click the particular report…,… to be display… then filters will be diplay… u can find four tabs naming “view” , “properties” like… click on Properties in that u can find parameters/… … then u can check the pick box for AX_company… it will be rendering in SSRS… Filters
in precision design after previewing am having lot of parameters so i have to keep on scrolling the scroll bar each time if i need to preview it ,so is their anyway to allign some of the parameters to the right
