smnehal
#1
when message send from .Net applcation into MSMQ
the following error occurs
Insufficient resources to perform operation
The messaege size is greater than 4MB.
All other message working fine, send and receive message from .Net application to Navision.
how can i increase MSMQ message size.
syed
babrown
#2
4 MB is the MSMQ message size limit when processsing ASCII messages. (It’s 2 MB for unicode). This can’t be increased. You might have a look at http://msdn.microsoft.com/en-us/library/ms935683.aspx
I’ve never tried this but it may help you to resolve your issue.
smnehal
#3
This is for biztalk, but i am sending message using Navsion.
Syed
babrown
#4
You are still using MSMQ. That’s where the limitation is.
smnehal
#5
Can i use BizTalk adopter rather than MSMQ Bus Adopter to sending messages using MSMQ, like BizTalk Message Queuing Large Message Extension
(MQRTLarge.dll)
give me some example with source code.
thanks
jsrark
#6
Only if you use Biz Talk…
