How i link between dimension value table and Gen. Journal Line table by employee code in test report
In Financial Management section - Cash Management - Cash Receipt Journal I want to add Employee code to
table Gen. Journal Line when account no is staff account The source table of this form (Cash Receipt Journal number 255)
is Gen. Journal Line and Source table of employee code is dimension value table how i can make link between two table to
display employee code in report number 2 general journal test.because when i make test report i don’t know how i can get
employee code to this stuff account
thanks
Did you add Employee Code dimension in Cash receiot Journal from Line–>Dimensions
And while printing test report, Check Show Dimensions under Options tab>
OK this quick way i thanks for it
But if i need to add this field to the table gen.journal line and link it from dimension value table how i make this
I mean this task can made by flow field
Add one field in Table no 81 and go the properties of that added field
Go to properties Table Relation
Select Table :- Dimension Value
Field :- Code
Table Filter :- Here Set filter for Global Dimension No as per your selection in General Ledger Setup -->Dimension i.e Here you have to select Shortcut dimension no.
OK thanks for reply but in last line after table filter :(Table Filter :- Here Set filter for Global Dimension No as per your selection in General Ledger Setup -->Dimension i.e Here you have to select Shortcut dimension no.) can you show this point more detail if possible
what i write in field and value and what field i must create in tables and which tables
the picture found in this link
http://www.mediafire.com/?0fo4o0zdq9m01d9
please help me
Go to General Leger Setup
Go to Dimension Tab
In this tab you are fixing the dimension as per the requirement
Now e.q if you setup you dimension ‘Employee’ in Shortcut Dimension 1 Code field then you need to set following in the employee field of table 81
Field :- Code
Table Filter :- 1
Hope this clear your requirement
OK THANKS
