In AX 2012, how do you set a sales order to hold? That is I entered it but I don’t want it to ship, just wait?
Hi
Product and information management–>Common–>Released products–>Manage inventory (tab)–> Default Order settings.
Select Sales order tab as per your specific needs and check the check-box ‘Stopped’
So whenever we try to create a sale order the transaction get blocked and pop up an message the Item is on hold.
Regards
Nijil
What if I just want to put a single order on hold? Is there a way to set a specific Sales Order on hold?
Select that particular sales order and in the Line details/General tab mark the field Stopped in the Status section. You can do it for a particular line in SO or all lines.
In AX2012 R3 you use the new “Order Hold” functionality - highlighting the lack of this clear functionality in prior versions
Could you guide me where the functionality is avaialble in Ax 2012 R3 ?
Sales and Marketing - Setup - Sales Orders - Order Hold Codes
More here: http://technet.microsoft.com/EN-US/library/dn631644.aspx
How to set credit hold on sales order? using given method on AX2012R3.
