In the Recurring General Journals, there is a “Journal Import” button.
Is there a standard template to use to be able to upload into the recurring Journal?
How do i get an excel file ready that can use this?
We are currently manually keying in all the entries.
P.S. Have only been using Dynamics NAV for about 4 months. [:)]
Thank you all for your help…
Welcome to DUG!!!
You need to learn /understand data migration utility of Navision .
You will find this in Administration Menu->Application Setup->Company Setup->Data Migration
Here you have to slelct the Table No. let say 81 for Journal & then you have to specify the Data Migration fields .
You can then Export the structure & then Import it after filling the data.
In the last you have to Apply Migration Data
Alternatively you can use dataport/xmlport to upload the version depend on the which client you are using …
Thank you very much. For what i am doing right now, this works perfectly.
Thanks again.
