I want to say, If column1 = “yes”, then column2 is mandatory. I’d like to do this through code, as column 1 can change. Can this be done?
Column1 | Column2 | |
Yes | Mandatory | |
No | abc | |
Yes | def | Mandatory |
Yes | Mandatory | |
No |
Yes | Mandatory | |
No | abc | |
Yes | Mandatory | |
No |
Hi Alex,
In the Form, make column2 AutoDeclaration to Yes.
In the init() method of the form place this code Table_column2.mandatory(false).
In the form datasource – fields – column2(field) – override the modified() method
public void modified()
super();
if(table.Column1 == NoYesCombo::Yes)
Table_column2.mandatory(true); //Table_column2 – name of the column2 in the form grid level…
else
Table_column2.mandatory(false);
Naresh kolli
Thanks for the reply. This makes the entire Column2 mandatory based on Column1 unfortunately. I would like to make only specific fields mandatory.
The other option would be overriding the validateWrite() method…
